Author Topic: LED Daylight Running Lights  (Read 1054 times)
Offline stealth
    • Hook, Hampshire
« on: April 12, 2014, 03:05:59 pm »
I've changed to LED Daylight Running Lights but on the drivers side, 2 of the lights keep flashing, when the car is locked and engine off.
Is this a MOT failure & can the DRL dash error be turned off via a garage software when hooked up to the car.
    Offline Juggler
    Re: LED Daylight Running Lights
    « Reply #1 on: April 12, 2014, 06:39:54 pm »
    I may be wrong. But all the posts I have seen on LED/DRLs are unable to get them to work with the Canbus (whatever that is... Anyone?).
    Some sites are selling them as "compatible" - but it seems they're not. You may end up taking them off....
    Maybe you can answer this (as I don't get it- not down wiv da kidz maybe?), why are some obsessed with changes the lights to LED?
    Offline FullMetalScorpion
    • APE Supersport+
      • A Small Town In Sheffield
    « Reply #2 on: April 12, 2014, 06:58:12 pm »
    The Canbus system basically checks the voltage on every bulb and if low indicates a warning because it thinks the bulb has blown. With LED style bulbs they have a low power draw so the system always thinks the bulb is faulty. Im sure I read somewhere that this wasnt a problem on the Evo models just the Grande.
    Offline stealth
      • Hook, Hampshire
    « Reply #3 on: April 15, 2014, 07:19:29 pm »
    Here's part 1 of the DRL bulb change, If the LED's i've bought don't work i'll stick with these as they are white / bright enough & will pass the MOT.
