Author Topic: Oil temperature measurement with diagnosis device  (Read 2254 times)
Offline Sander
    • Belgium
« on: March 21, 2015, 12:31:55 pm »
Hello
I'm wondering if you can read the oil temperature with a diagnosis device, is it possible?
Because I would like to buy a device so I can measure the oil temperature? Does the multi-air engine have an oil temperature sensor that's linked with the ECU? Because I've been in a Subaru '99 a while ago and he had a device that you can measure the oil temp, water temp, lambda and few other things I'm not sure if it's stock though because I thought that would be an easy way to know when the engine's oil is on the right temperature.
Thank you
Forge Intercooler, Forge Dumpvalve, H&G Intake, G-Tech Shortshifter, G-Tech End Muffler, ECU Remapped.
    Offline jackslade
    • Carlo Rating: 7
      • Birmingham
    Re: Oil temperature measurement with diagnosis device
    « Reply #1 on: March 21, 2015, 01:46:18 pm »
    I use torque pro app, through phone and obd2 mini connector.
    Abarth 500 Esseesse black 2011, black gloss wheels, red stripes & mirrors, red leather, monza, clarion head unit, cruise control, cat 1 & anti hijack alarm system,auto close windows,acci cam,Piaa DRL's.2 seater, Black surround rear lights. Wrapped Bonnet(carbon Fibre)
    Offline Sander
      • Belgium
    « Reply #2 on: March 21, 2015, 02:30:04 pm »
    So it's possible to read the oil temp with the app?
    Offline jackslade
    • Carlo Rating: 7
      • Birmingham
    « Reply #3 on: March 21, 2015, 03:03:06 pm »
    Sorry to mislead you, just checked and I had changed its name, its the transmission temperature (code 3). Whatever that means, but when stationary its the same temp as the coolant. There is no data on oil temp. Again I do apologize.
    Offline Sander
      • Belgium
    « Reply #4 on: March 29, 2015, 01:27:45 pm »
    Hello i've bought a bluetooth adapter same with the torque app.. Could you give me the PID's because it's difficult to find them..
    Offline jackslade
    • Carlo Rating: 7
      • Birmingham
    « Reply #5 on: March 29, 2015, 02:29:26 pm »
    PID's your getting technical now, I just connect to the ones in green, I have the fiat advanced app but as most of this is USA there is no 500 Tjet.
    Offline Sander
      • Belgium
    « Reply #6 on: March 29, 2015, 08:36:21 pm »
    Oh.. Didn't know about the fiat app, thanks alot!
