Author Topic: Raspy Sounding Induction Kit?  (Read 889 times)
Offline ABZedd
    • Bucks
« on: March 25, 2014, 05:54:37 pm »
At the mo I have the SS BMC Air filter on, but I would like to hear the engine roar a little more from inside. It does sound good and throaty from about 3500rpm to 6000rpm but I was wondering if there if an Induction Kit that would make it sound more raspy and sporty, but not sucking/whooshy sounds nor dump valve sounds, all of which I hate.
Cheers.
ITALIAN
--AND--
PROUD  8)
    Re: Raspy Sounding Induction Kit?
    « Reply #1 on: March 25, 2014, 06:04:58 pm »
    BMC CDA might give the desired response, anything open-cone will promote the things you don't like :)
    Offline ABZedd
      • Bucks
    « Reply #2 on: March 25, 2014, 06:23:21 pm »
    This one?: http://www.bmcairfilters.com/cda-carbon-dynamic-airbox/accdasp-44_d744_1.aspx
    Am I right in saying that the alternative to open-cone is enclosed then and what I should be looking at? Or is there more?
    ITALIAN
    --AND--
    PROUD  8)
    « Reply #3 on: March 25, 2014, 07:00:39 pm »
    Yeah, the theory is that an enclosed system will suppress the wastegate chatter where as an open cone will amplify into the surroundings, which is what you don't want..
    I don't know for sure if a CDA will give the desired result or not...
