Author Topic: Replacing standard APE brake pads  (Read 927 times)
Offline stealth
    • Hook, Hampshire
« on: March 14, 2014, 09:04:21 pm »
I've bought a set of racing brake pads which i'm going to try & fit tomorrow, just want to know if the brake pads are the same as a normal car where you swap them over, or do they need anything extra to work with the Brembo calipers.
    Re: Replacing standard APE brake pads
    « Reply #1 on: March 14, 2014, 09:29:05 pm »
    you need to be brave to punch out the securing pins, concave headed punch will help, you don.t want to chip the red paint :thumb:
    Offline stealth
      • Hook, Hampshire
    « Reply #2 on: March 17, 2014, 08:04:13 pm »
    Replaced the pads today, a straight swap with no problems, Mintex Part Number :MDB3207 .
    Offline AnotherRandom
      • Perth
    « Reply #3 on: March 17, 2014, 08:22:59 pm »
    Remember racing brake pads are designed to operate at different temperatures than standard road pads. I would make sure they are suitable for road use before you end up going straight through a corner.
    Offline sandys
      • Bristol
    « Reply #4 on: March 17, 2014, 09:12:11 pm »
    That code relates to standard pads, he should be fine.
