Tuning & Modifications => Abarth Punto Evo => Topic started by: stealth on March 14, 2014, 09:04:21 pm
Title: Replacing standard APE brake pads
Post by: stealth on March 14, 2014, 09:04:21 pm
I've bought a set of racing brake pads which i'm going to try & fit tomorrow, just want to know if the brake pads are the same as a normal car where you swap them over, or do they need anything extra to work with the Brembo calipers.
Title: Re: Replacing standard APE brake pads
Post by: lloyd on March 14, 2014, 09:29:05 pm
you need to be brave to punch out the securing pins, concave headed punch will help, you don.t want to chip the red paint :thumb:
Post by: stealth on March 17, 2014, 08:04:13 pm
Replaced the pads today, a straight swap with no problems, Mintex Part Number :MDB3207 .
Post by: AnotherRandom on March 17, 2014, 08:22:59 pm
Remember racing brake pads are designed to operate at different temperatures than standard road pads. I would make sure they are suitable for road use before you end up going straight through a corner.
Post by: sandys on March 17, 2014, 09:12:11 pm
That code relates to standard pads, he should be fine.
