Abarth Cars => Abarth Punto Evo => Topic started by: AndrewG on November 27, 2015, 08:27:58 pm
Title: Engine light on. No start stop - P1063
Post by: AndrewG on November 27, 2015, 08:27:58 pm
Hi guys, recently had my engine light come on a few times, goes off occasionally and usually comes back on when fuel is low ~>100 miles. Until now there has been no noticeable drop in power and now tonight it came back on and the car struggled for a few seconds as if it was possibly running on 3 cylinders. Had it plugged into diagnostics, came back with fault code P1063, "cylinder 3 uniair actuation electroval signal. Anyone shed any light on this? Also, can anyone recommend any garages in or near Glasgow who knows there way about an Abarth?
Many thanks.
Title: Re: Engine light on. No start stop - P1063
Post by: Andrew on November 27, 2015, 08:49:16 pm
Sounds to me like the start of multiair failure.
What grade oil have you been using?
Post by: AndrewG on November 27, 2015, 09:59:31 pm
When I bought the car just under a year ago it had a full abarth service history so unsure what would have been used, however I am just after servicing it 5k miles ago using 5w40
Thanks for your reply :)
Post by: Andrew on November 28, 2015, 01:38:23 pm
Glad you've used 5/40. I'd get your car booked in ASAP.
Post by: AndrewG on November 29, 2015, 10:39:34 am
Just glad I done a good bit of research instead of just going with the manual! That's my next step just trying to find someone who knows a bit about them before ripping it apart!
Post by: kingkongiswrong on August 25, 2016, 08:57:11 pm
I've had same problem for about 2 months now. It comes on for like once a week then goes off again.
 When it went for its 4th service I thought it would get fixed but unfortunately they just put it down to an electrical problem that they couldn't trace! (Wessex Cardiff).
However it's definitely not as you can feel a performance lag (cylinder problem I suspect now) when the warning light comes on.
Post by: J_a_m_e_s on August 26, 2016, 10:43:38 am
Had this with mine about a year ago. Stop and start warning comes on with check engine light, after a bit the judders start and lack of power. Garage (Wessex Cardiff abarth) said it was a split vac pipe. Not had the problem since touch wood. Never plugged it in to find an error code my self tho.
