Author Topic: front discs and pads  (Read 857 times)
Offline nickhartwell
    • northampton
« on: August 08, 2014, 06:57:11 pm »
Hi all its time to get front discs and pads changed. I'm very confident in changing brakes as done loads before but this is first time on my punto evo. Had a route around and pads seem easy just discs? Are they easy with regards to replacing. Happy to listen to opinions or if someone local consider helping sure we can come to some arrangement
Nick
    Re: front discs and pads
    « Reply #1 on: August 08, 2014, 08:23:13 pm »
    thery're straight forward enough, the caliper bolts are very tight however, took a 600mm bar to crack them when I did mine, just enough clearance using a jack if you put the wheel on full lock :thumb:
