Abarth Cars => Abarth Punto Evo => Topic started by: nickhartwell on August 08, 2014, 06:57:11 pm
Title: front discs and pads
Post by: nickhartwell on August 08, 2014, 06:57:11 pm
Hi all its time to get front discs and pads changed. I'm very confident in changing brakes as done loads before but this is first time on my punto evo. Had a route around and pads seem easy just discs? Are they easy with regards to replacing. Happy to listen to opinions or if someone local consider helping sure we can come to some arrangement
Nick
Title: Re: front discs and pads
Post by: lloyd on August 08, 2014, 08:23:13 pm
thery're straight forward enough, the caliper bolts are very tight however, took a 600mm bar to crack them when I did mine, just enough clearance using a jack if you put the wheel on full lock :thumb:
