Author Topic: Seat Bolster  (Read 1020 times)
Offline Paveway
Seat Bolster
« on: November 01, 2012, 01:20:40 pm »
With less than 300 miles on the clock, does anyone think it is acceptable to have a seat Bolster that is damaged ? I certainly do not and am awaiting a call from the Dealers to explain what has happened.
It would appear that the supporting foam on the passenger side has folded / collapsed, leaving creased up seat  material around this area. Almost like masses of excess skin on a skinny person who was once extremly fat  :-X
Has anyone else had this problem with the standard seats ?
David
If you can see Chuck Norris, he can also see you.
If you can`t see Chuck Norris, you may be only seconds away from death
