Author Topic: Windscreen Wiper Fluid Reservoir  (Read 1889 times)
Offline Blacken
  • Abarth Punto Evo Supersport
    • Down in the sewer, W.London
« on: November 19, 2014, 11:39:33 am »
I was just checking under the bonnet this morning and I had a quick look at the windscreen wiper fluid reservoir.
Now it is not that easy to see how much fluid there is in the reservoir because it is obscured by the surrounding engine parts. I took the filler cap off and the vertical filler tube which supplies the reservoir appears to be empty - the little gauze filter half way down is visible. I checked the handbook and it is rather vague about the subject.  ???
Any ideas how I can gauge how much is in there and how far it should be topped up?
Past: Abarth 500 White + red stripes,
Abarth 500 Esseessee White + black stripes, Abarth Punto Evo Esseessee Velocity Red + White stripes,
Current: Abarth Punto Evo Supersport in 1949 Glory White with Black Sidestripes.
    Offline Brian1612
      • Glasgow
    Re: Windscreen Wiper Fluid Reservoir
    « Reply #1 on: November 19, 2014, 12:19:12 pm »
    Until it starts to overflow ;)
    « Reply #2 on: November 19, 2014, 12:21:47 pm »
    Top it up until you see fluid :thumb:
    Only way of finding out if you run out is when it goes all foamy and you lose pressure ;)
    Offline Blacken
    « Reply #3 on: November 19, 2014, 12:47:14 pm »
    Should it be above the gauze filter?
    Offline AustinR
    « Reply #4 on: November 19, 2014, 01:10:39 pm »
    It doesn't really matter if it comes up over the filter when you top it up. It will soon go down when you use the screen washers a few times ! Screen wash isn't like brake fluid or engine coolant. There's no minimum or maximum levels which you must adhere to. Just make sure you've got some in there. Incidentally, I use cheap High Street screen wash which I decant into an old pop bottle and mix with water at something like 30% wash for summer use, and 50% for winter. It helps if you use a plastic funnel when you fill up to avoid spillage. When it starts foaming out the top of the filler spout you'll know there's enough in !
    Offline Blacken
    « Reply #5 on: November 19, 2014, 01:23:39 pm »
    Thanks Austin, I have ordered some Tutela SC35 to be delivered to my workplace so I will be filling up soon.  :thumb:
    Offline Blacken
    « Reply #6 on: November 26, 2014, 06:30:43 pm »
    Just for the record, l ended up putting in over 1.5 litres so it was pretty much empty. Seems to work fine now. :thumb:
