Author Topic: Won`t Start  (Read 2574 times)
Offline redreg
    • Sleaford Lincs
Won`t Start
« on: February 03, 2016, 05:52:43 pm »
Has anybody had any issues with not starting.The vehicle started OK,I drove approximately 1/2 mile,turned the engine off and when I got back in the car I was greeted with a CODE fault emblem in the dash display followed by fuel cut off not available then start/stop not available and then check power steering with a large red steering wheel.The engine would not turn over,then the climate control fan started blowing at max and the outside temp gauge was indicating -40.RAC couldn`t sort it and the garage they`ve taken it to say that they the car computer isn`t communicating.Not sure whats going on.So some help would be appreciated.The cars warranty has just expired,6 weeks ago so FIAT will wash their hands.
    Offline Lethal
      • Lancashire
    Re: Won`t Start
    « Reply #1 on: February 03, 2016, 08:37:19 pm »
    Has your battery failed? So many gremlins in one go might be due to a cell failing and the voltage being low. Only a guess.
    Re: Won`t Start
    « Reply #2 on: February 03, 2016, 09:10:21 pm »
    Certainly your battery and it's connections should be your first port of call :thumb:
    Offline redreg
      • Sleaford Lincs
    Re: Won`t Start
    « Reply #3 on: February 03, 2016, 10:56:43 pm »
    Everything electrically appears to be working as it should except it won't start.  ???
    Offline studoc72
      • Glasgow
    Re: Won`t Start
    « Reply #4 on: February 04, 2016, 09:42:49 am »
    It would shock you what a failed battery can do.
    Have it voltage and drop tested.
    Offline redreg
      • Sleaford Lincs
    Re: Won`t Start
    « Reply #5 on: February 10, 2016, 04:04:27 pm »
    Punt now sorted. Broken wiring to the slewing sensor connector in the centre tunnel. Probably damaged at manufacture. Good old Rockingham Cars in Corby. ;D :thumb:
