Author Topic: 'Woooing' noise in reverse  (Read 2479 times)
Offline SteveM
    • West London
« on: January 01, 2016, 07:11:56 pm »
Hi all,
I just wanted to see if anyone else here has experienced the 'whooing' noise when reversing.
It usually happens after a bit of a drive and when you're a little heavy on the peddles.
I know I'm not the only one that has experienced this same phenomenon after a couple of google searches. I'm pretty sure this is a clutch issue but that's where my problem begins. The car is still under extended warranty but the warranty company will not cover it if it is an issue with a perishable part. So I have to make a decision as to how I proceed.
Has anyone else had this issue and if so, how was it resolved? What was the fault and did the Warranty cover you?
TIA
Steve
    Offline Remy
    Re: 'Woooing' noise in reverse
    « Reply #1 on: January 02, 2016, 02:49:19 pm »
    Hi
    I get a high pitched noise when setting off in first or reversing when the car has just started and is running from cold. After the engine has been running for a bit that noise goes away. I don't think it's anything to do with the clutch as I would have thought it would be doing it all the time.
    I don't know if you experience similar problems? It could be the pipes from the turbo perhaps although that would cause a loss in boost  I would have thought.
    With regard to your warranty - how old is your car. Did they extend the full manufacturers warranty? They will probably try to get out of any repairs by saying it is wear and tear
    Remy
    Abarth Punto Evo, White, Red Stripes, Sunroof, Climate, Auto Windscreen Wipers, Electrochromatic Rearview Mirror
    Offline nickhartwell
      • northampton
    « Reply #2 on: January 02, 2016, 03:24:39 pm »
    i had a whining noise in reverse at slow speed which turned out to be clutch release bearing
    Offline SteveM
      • West London
    « Reply #3 on: January 02, 2016, 06:17:30 pm »
    Yeah that's what another guy on another forum said it was with his but he described the same phenomenon as I have, ie reversing, not at high speed but with a bit of lead footedness. I demonstrated it to one of the mechanics at Thames Fiat but applying the handbrake hard and trying to reverse.
    The car is a 2012 plate with 22k on the clock but I noticed it when I bought it at 18k. It's a full extended warranty but I'm not sure how it works because the service manager had to call the warranty 'comapany' to see what they say and they will investigate but if it's a perishable part then they won't hold themselves accountable. Hence the thread. I want to see how many other people have had this issue to try to determine the financial risk to get them to sort it. I appreciate all the imput  :thumb:
      • northampton
    « Reply #4 on: January 03, 2016, 10:17:20 am »
    i bought mine at 3 years old and it came with an extended years warranty from abarth. they had to get an independent assessor out which took about a week but at 26k i had clutch flywheel and bearing replaced under warranty
    Nick
