Author Topic: Abarth 500, removing side indicators.  (Read 8690 times)
Offline PORTHOS
    • Devon
« on: April 14, 2015, 11:58:52 am »
Small DIY for removing the side indicators for black ones or changing the bulb without fender liner removal, the manual says: Prise the point indicated by the arrow, so as to compress the fixing clip..... which isn't the most helpful.
If you use a small plastic card and a bit of detailing spray/car shampoo for lubrication you can slot the plastic card behind the indicators as pictured here:
1. Slide the card behind the indicator in the direction of the front of the car to the back until you hear a pop sound from the clip.
2. Repeat from rear to the front of the car (this bit is a bit harder) and the indicator will pop out cleanly.
Hey presto :)
« Last Edit: April 14, 2015, 05:17:03 pm by PORTHOS »
