Author Topic: Any Ideas??  (Read 1756 times)
Offline Lisa1626
Any Ideas??
« on: August 23, 2009, 12:09:09 pm »
Up until about 2 days ago my ipod has been playing fine and now its decided that its not going to work at all!
Any ideas why this might be, its really frustrating!  ???
    magicmole
    Re: Any Ideas??
    « Reply #1 on: August 23, 2009, 03:49:04 pm »
    Flat battery?
    Offline Lisa1626
    Re: Any Ideas??
    « Reply #2 on: August 23, 2009, 04:52:17 pm »
    Flat battery?
    [/quote]
    Nope, battery is fine, it was playing fine, then it started to not play certain tracks.
    Now it doesnt play anything lol.
    olopboy
    Re: Any Ideas??
    « Reply #3 on: August 23, 2009, 10:39:09 pm »
    You have been pluging it into the dongle in the correct sequence? I have heard it gets upset if you don't do it exactly as the instructions say.
    Offline Hozepipe
    Re: Any Ideas??
    « Reply #4 on: August 24, 2009, 08:01:41 am »
    If that doesn't work, you could try disconnecting the car battery (wait 20mins after use). It appears to solve a multitude of B&M sins. >:(
    Offline Lisa1626
    Re: Any Ideas??
    « Reply #5 on: August 24, 2009, 10:33:47 am »
    Whats the correct sequence lol. Im not sure whether or not it'll work if i just transfer everything onto a memory stick?
    olopboy
    Re: Any Ideas??
    « Reply #6 on: August 24, 2009, 11:00:22 am »
    Ah for proper I-Pod playback there is a seperate dongle you can buy which specifically allows for the playback of acc (Itunes) files. However it costs a bit and I would say unless you have an i-phone the cost possibly outweighs the effort needed to convert the acc files to mp3 and then load them on a usb stick.
    Offline needsmust
    Re: Any Ideas??
    « Reply #7 on: August 25, 2009, 12:39:52 am »
    Will I be able to play "borrowed" aac content on a USB?
    grigio campovolo - kit estetico nero - pelle nera - tetto in vetro fisso - cerchi in lega 16" - koni FSD - molle SS - G-Tech S - stolen 2017
    Ghiacchio Comp, all options.
    olopboy
    Re: Any Ideas??
    « Reply #8 on: August 25, 2009, 08:48:51 am »
    No acc content, borrowed or not, from the USB it must be MP3 (might support wav as well can't remember off the top of my head). To use acc files directly you need to play them through an ipod via the adapter
