Author Topic: Blue and me meltdown  (Read 6149 times)
Offline davidj1888
« on: June 08, 2009, 09:23:50 pm »
Hi all, got my first flash drive yesterday and promply downloaded my music collection onto it and plugged it into the car.
Everything seemed perfect other than the, genre artist function not working too well, but I ve put this down to most of the songs being downloads :whistle: and possibly not containing all the relevant tags the blue and me requires.... I  set the system to shuffle and it seemed to be fine.
On starting the car tonight I found I could not skip tracks, and when attempting to access the voice command menu nothing happened and on further investigation the phone button will no longer work??? so it seems to be f*&^%ed
any ideas anyone??
Launch edition, bosa nova white, red leather blah blah blah
    Re: Blue and me meltdown
    « Reply #1 on: June 08, 2009, 09:33:24 pm »
    How many tracks are on the stick?
    Offline davidj1888
    « Reply #2 on: June 08, 2009, 09:39:13 pm »
    About 150, its the flash drive that rich recommended, it was working ok for a couple of days
    any ideas Alex
    « Reply #3 on: June 08, 2009, 10:04:41 pm »
    Try another stick with just a few tracks on if you have one.  If you don't, try shuffling the tracks around on it (delete a couple, add a couple) on your PC before re-inserting it.
    Re-insert it with the ignition off, turn the ignition on and give it time to rebuild its index before starting the engine or doing anything with the menus/phone.
    Let us know what happens.
    Offline davidj1888
    « Reply #4 on: June 08, 2009, 10:16:51 pm »
    Cheers Alex, I'll give that a try tomorrow and see what happens... I've just started using the B&M so no doubt there'll be a few more posts :thumb: and I don't think my iPhone helps matters much though it does pair just no phonebook but that's another thread
    Offline euroboy
    • An Englishman in Holland
    « Reply #5 on: June 09, 2009, 08:42:56 am »
    If nothing else works you will have to disconnect the battery -VE leade for a couple of minutes to do a full reset.  I have had to this a cople of times now.
    Welcome to Blue and ME!
    Abarth 500
    G-tech 'S' chip.
    G-tech full exhaust sytem.
    172bhp & 285Nm @4850rpm.
    Now sold - doh!
    olopboy
    « Reply #6 on: June 09, 2009, 09:06:41 am »
    just no phonebook
    You may need to send your contacts individually via bluetooth like a fair few of the Nokia Smartphones have to.
    Offline Hozepipe
    « Reply #7 on: June 09, 2009, 09:41:59 am »
    Make sure the car is left to rest for at least 20mins before disconnecting the battery. :-[
    Offline Andrewfuzzy
    « Reply #8 on: June 09, 2009, 04:12:52 pm »
    Maybe the dealers should install a reset button in the dash like all computers have
    Offline davidj1888
    « Reply #9 on: June 21, 2009, 05:03:34 pm »
    i m going to try and reset the blue and me as its still not working can someone confirm the procedure...
    1/ Turn off car and leave for 20 minutes.... why do you have to do this? i ve seen it mentioned but im not sure why it has to be left for 20
    2/ disconnect battery... is it the positive first or the negative as i always thought it was the + first as most cars are earthed through the -
    3/ I assume i will loose all info and the settings will go back to factory
    Offline euroboy
    « Reply #10 on: June 21, 2009, 05:34:45 pm »
    I also haveno idea why you have to leave it for 20 mins - I didnt (and it didnt seem to cause any problems)!
    You will only need to disconnect the -ve terminal, its a simple clamp and you dont need any tools.  Make sure you leave it for 5 mins or so and then reconnect.
    Abarth 500
    G-tech 'S' chip.
    Now sold - doh!
    Offline davidj1888
    « Reply #11 on: June 21, 2009, 05:37:55 pm »
    Thanks euroboy I ll give that a go right now...if you hear a faint explosion in the distance you ll know where it came from
     :thumb:
    Offline davidj1888
    « Reply #12 on: June 21, 2009, 06:53:57 pm »
    That's the blue and me working  again ... Thanks guys :thumb:
    Offline Joe
    « Reply #13 on: June 21, 2009, 09:39:16 pm »
    I loved blue & me in my Fiat 500. It's a sack of donkey s**** in my Abarth. How can the same system differ so much in terms of functionality between cars?
    « Last Edit: June 22, 2009, 12:48:55 am by olopboy »
    Offline Hozepipe
    « Reply #14 on: June 22, 2009, 09:11:57 am »
    Come on Joe, its not that good, but seriously, does your phone behave differently in the A500?
    « Last Edit: June 22, 2009, 04:55:01 pm by Hozepipe »
