Abarth Cars => Blue&Me => Topic started by: cloudburst on October 25, 2016, 10:36:11 pm
Title: iOS 10 has broken Blue&Me
Post by: cloudburst on October 25, 2016, 10:36:11 pm
My iPhone 6 always worked fine in my A500 (my car is late 2011 with the newer setup that didn't need the extra dongle).
However, since I upgraded to iOS 10, the bluetooth connection drops early during calls. I thought iOS 10.1 might cure the problem, but no such luck.
Symptoms:
- When I initiate a call from the steering wheel, the call will ring and mostly work long enough for the call to be answered, then a few seconds into the call, the dash will display "NO BLUETOOTH" and then "PHONE ON" and the call will still be in session on my iPhone.
- If I then select something like "LAST CALLS" from the steering wheel, after displaying "SEARCHING" for a while, Bluetooth will reconnect, but if I make another call, the same thing will likely happen.
- If I am already in a call before starting the car and the call transfers onto Blue&Me when it gets turned on, then everything will work just fine.
I've tried deleting all users and all user data and re-pairing, but this didn't resolve the issue.
Has anyone else had the same problem?
Any advice?
Thx.
CB
Title: Re: iOS 10 has broken Blue&Me
Post by: GTMartin on October 26, 2016, 09:03:10 pm
Have you tried a hard reset on the phone?
Post by: cloudburst on October 26, 2016, 11:34:28 pm
Yep thsnks. Tried that.
Interestingly - I removed reo bluetooth pairings to a Divoom Aurabox bluetooth speaker and subsequently my iPhone was working this afternoon with Blue&Me.
Paired my iPad to the Divoom speaker in the meantime so that I can continue to monitor my iPhone with Blue&Me as its only pairing.
Will report back in a few days.
CB
Post by: cloudburst on November 03, 2016, 02:43:27 pm
Update as promised...
All has been fine with Blue&Me/iPhone6/iOS10 since I 'forgot' the other bluetooth pairings on my iPhone.
Will re-introduce them and see if things still work.
CB
