Author Topic: Different Settings  (Read 12741 times)
Offline oVerboost
    • United Kingdom
Different Settings
« on: September 06, 2017, 06:14:59 pm »
This is really for the bluespark guys on the forum, as I know it gets asked a lot, more so on the facebook groups etc but it would be good to know what settings you recommend.
For example, setting C on a standard car. But setting D for cars with an exhaust and filter perhaps? I'm not saying that is the correct theory, but I've seen it asked a few times and people's replies vary so much.
The paperwork with the boxes states that it's probably best to leave it on setting C, but at what point is D and E recommended?
Thanks.
    Offline edd@bluespark
      • Houghton le Spring
    Re: Different Settings
    « Reply #1 on: October 19, 2017, 05:35:44 pm »
    Hi there,
    It very much depends what spec your car is and what revision of the firmware is on your box. If you can tell me your order details I can look it up for you and give you some advice?
    Best regards,
    Edd
    Bluespark Automotive Ltd - Plug and Play Tuning Solutions - See what we can do for your Abarth here: https://www.bluesparkautomotive.com/abarth-tuning
    Offline simmouk
    • HOON
      • Coventry, UK
    « Reply #2 on: October 21, 2017, 08:27:05 pm »
    I've got a stock 66 plate 145 Abarth 595, which dyno'd at 148hp a few months ago. I've got a Bluespark fitted and I've had it on C for a few weeks and I immediately felt the extra power. Got it dyno'd again today and got 153hp - after discussing on Facebook with others I'm confident it will be an even better read out on D or E. So I took it out for a spin in D and felt the pull yet again - upped to E and it really does go!
    I too thought that D and E were for cars with upgraded exhausts, intakes etc but it seems to run really well in both D and E!
    So I would say, start off in C, then after a few weeks, notch it up to D or E? Smiles per mile guaranteed!
    Classic Mini > Fiat 500 > Abarth 500 > Abarth 595. Pocket rockets to pocket rockets!
    Offline oVerboost
      • United Kingdom
    « Reply #3 on: October 22, 2017, 10:27:20 am »
    I was the one that said up it to setting E on facebook bud  ;)
    When I wrote the post above, I didn't mean it to sound like a question from me. I meant it so that the guys at Bluespark could explain what settings work best with different mods, as it gets asked a lot and would be a good reference point. I've had two boxes and both work best on setting E with no issues.
    Glad yours is working well now Simon  :thumb:
    Offline oVerboost
      • United Kingdom
    « Reply #4 on: November 02, 2017, 06:21:18 pm »
    For reference, I had my Esseesse dyno tested at the weekend after having a new clutch fitted a couple of weeks back.
    Box was on Setting E. Car has done 72k miles with the original turbo.
    Supporting mods are a bmc panel filter (standard Esseesse part) and a Milltek full stainless resonated system and BP Ultimate fuel.
    Results were impressive!  8)
    Offline Fieldgate
      • Jctn 9 M1
    « Reply #5 on: December 12, 2017, 05:40:39 pm »
    I'm more interested in the torque number than the HP.
    Do any of the settings focus more towards that ?
    Offline oVerboost
      • United Kingdom
    « Reply #6 on: December 12, 2017, 05:55:25 pm »
    Yes, D and E are higher torque than C.
    Offline Fieldgate
      • Jctn 9 M1
    « Reply #7 on: December 28, 2017, 05:47:59 pm »
    16-Reg Tourismo and Fitted BS-box this past week - only a selection of profanities and scratches getting to the boost plug under the battery...
    Setting C was OK, but still wouldn't want to drive round outside of Sport
    Then today, had a Monza fitted I picked up out of the classifieds, that I wired the valve open with the original spring.  That made a bigger difference even on C. as well as the better noise.
    Have upped to D to see the change and yes there is something - but was getting dark.....will try E tomorrow !
    Generally, much happier !!!
    Offline Jenko
    « Reply #8 on: January 02, 2018, 01:43:41 pm »
    Did you try E?.......Interested in result.
    Offline Fieldgate
      • Jctn 9 M1
    « Reply #9 on: January 02, 2018, 04:07:56 pm »
    Yes I did - & have left it on E.
    Car runs absolutely fine on both settings - and you don't feel woefully short-changed on the non-Sport any more.
    Interesting to compare with my son, who had his 160hp Comp re-mapped at Pro-Alfa.  I think there is a bigger difference between the 2-settings with the Bluespark box.
    For the discount price from here, I'm very happy with the results.
