Author Topic: Differences between base 595 and Competizione?  (Read 3502 times)
Offline Col666
    • Fife, scotland
« on: February 16, 2019, 12:54:26 am »
What mechanical differences are there between the base 595 model and the Competizione?
Is it just an Ecu tweak or does the Comp have a different turbo/intercooler etc?
The deals on year old non Comp 595’s are great, I would like to know how easy it is to get to Comp levels of power.
v9photoworks
    Offline jpgibson
      • Sydney Australia
    Re: Differences between base 595 and Competizione?
    « Reply #1 on: February 17, 2019, 10:12:15 pm »
    The power bit will involve a remap or tuning box. The rest of it will be very expensive if you decide you want: Brembo front brakes, Sabelt seats, Monza exhaust, Koni's at the front etc.
    Offline 137699
      • Winchester
    « Reply #2 on: February 19, 2019, 08:31:18 am »
    Base 595 has an IHI turbo.
    Competizione has a Garrett turbo, uprated shocks & dampers, uprated brakes, bigger wheels (to fit over the brakes), uprated exhaust, uprated air filter, different map.
    Offline iAndre
    • Car Enthusiast
    • Pocket Rocket !!
      • Greece
    « Reply #3 on: February 24, 2019, 11:06:46 pm »
    Actually in the front both model comes with Koni FSD but on the rear only the Comp has Koni FSD. Also, Comp comes with different springs (lower than the standard 595). 17'' wheels instead of 16''. Note that the brembo brakes can also be fitted on the 16'' wheels! Last but not least, sabelt seats.
    Basically, the only mechanical difference is the turbo.
    Fitting the Garrett turbo and a remap will get you to the comp range. Standard 595 suspension can overcome the Comp setup. Same goes for the OE brakes but i would definitely suggest installing the brembo kit. The uprated bmc air panel filter costs around 70€. Rear suspension and springs can be found for less than 200€. Monza exhaust can be found at 240€-280€. Prices refer to used but good/great condition. Regarding remap, you can "install" the stock map from the Comp model.
    « Last Edit: February 24, 2019, 11:12:32 pm by iAndre »
    --------  myAbarth 2017  -------
    https://www.abarthforum.co.uk/the-abarthisti-garage/abarth-595-cabrio-1-4cc-145hp-first-impressions-upcoming-mods/
    Offline 137699
      • Winchester
    « Reply #4 on: February 26, 2019, 02:35:41 pm »
    Sabelt seats are no longer a given on the comp - you can now spec a comp with standard seats.
    And you should - the sabelts are horrifically uncomfortable.
    Offline FLP
      • Turnhout, Belgium
    « Reply #5 on: February 27, 2019, 10:57:33 am »
    uhg.. not this/you again  ::)
    2017 Abarth 595 Competizione with Performance Pack
    Mods: Some cosmetic stuff; Rear seat delete; Rear chassis braces; Side underskirts; Stage 1 remap 205hp, 332Nm
    Offline jaychief1
      • Manchester
    « Reply #6 on: March 25, 2019, 08:45:15 pm »
    Must admit I have suffered with my back down the years having sparco and Recaro seats in my mini's however the sabelt seats are like gloves !!!
