Author Topic: "range" - petrol  (Read 1836 times)
Offline Mac0389
    • Hornchurch, Essex
"range" - petrol
« on: June 15, 2014, 07:47:11 pm »
My range gauge in the amount of fuel I supposely have dances around like no ones business, 173 miles to empty then 213 a second later! Anyone else's do this?
Kieran
    Offline Tiptop
      • Canvey,Essex
    Re: "range" - petrol
    « Reply #1 on: June 15, 2014, 09:43:21 pm »
    Will change with your driving style, say after a section of heavy acceleration the mileage will obviously drop, mine stays fairly accurate if i'm cruising at 70-80. Stop start traffic makes it difficult to with the fluctuating mpg
    Offline Shant Ole
      • Larnaca
    « Reply #2 on: June 16, 2014, 10:39:40 am »
    The range is never accurate. It more or less tells you roughly but yes it does change depending on your driving style
    Offline Mac0389
      • Hornchurch, Essex
    « Reply #3 on: June 16, 2014, 05:35:11 pm »
    Thanks guys. This is when I'm in normal not sport setting... Still dances around everywhere
    Kieran
    Offline harry flatters
    • Carlo Rating: 4
      • norfolk
    « Reply #4 on: June 16, 2014, 07:21:49 pm »
    Range guage will definitely jump around just after a fill up. In the early miles of the predicted range, the driving style adopted, getting stuck in traffic etc will have a disproportionate effect on the reading as the software has only had very little 'sampling' to work on so tends to assume that whatever consumption you are doing at the time will be the same for the whole tank!!  As you tot up the miles on that tankful, the averaging of many more 'samplings' should see the range reading settle down to much smaller differences between readings shown.
    Nov 2012 A500, officiano red, 17' petals but otherwise standard (wife beats me severely about the head and body if I talk about customising but I did buy a logoed folding umbrella!) I just love it - the car that is! well, and the wife!!
    Offline scorpione bianco
    • When is a mouse when it spins?
    « Reply #5 on: June 16, 2014, 07:45:57 pm »
    I can cotinue driving for about 25 miles after the range is showing '--'.
    When I fill up to the brim I can then get about 35.5 litres in the tank.  I only adopt this practice as I'll be driving the 5 miles home.  I would NEVER do this and then leave the car without covering some distance, as the fuel may expand and cause spillage.
    A500ss, Funk white, Xenons, Climate Control, Skydome, Red Leather, Split rear Seats, Electrochromic Rearview Mirror. Record Monza Exhaust, Koni FSD Dampers, Supagard paintwork and interior treatment.
