Author Topic: Abarth GP Project  (Read 3783 times)
Offline SeanT-Jet
    • Hertfordshire
Abarth GP Project
« on: October 03, 2014, 03:41:41 pm »
Hey guys I'm gona start this thread as it's going to be a long project....I've got a 09 GP Abarth and the plan is to get it running over 300bhp... Now I don't know if it's been done already so any information will be much appreciated... So the plan is
Astra VXR injectors
GT2876 turbo
Custom exhaust system
Custom exhaust manifold
Forge intercooler
Standard rods and pistons for the time being (260bhp)
Forge DV
Cone Filter
And wherever I can get a decent map..
I'm gona post some pics up of the car and If you guys have any info that would be helpful to the build or even general knowledge I would very much appreciate it.
Regards
Sean T-Jet
    Offline SeanT-Jet
      • Hertfordshire
    Re: Abarth GP Project
    « Reply #1 on: October 03, 2014, 03:52:23 pm »
    Better quality coming soon..
    Offline KK_96
      • Manchester
    « Reply #2 on: October 03, 2014, 03:57:03 pm »
    Best of Luck, might want PM VBV Dan on here, his 500 is running 398 BHP at the minute I think :)
    Abarth 500 Campovolo Grey with them bright white eyes
    Offline SeanT-Jet
      • Hertfordshire
    « Reply #3 on: October 03, 2014, 04:32:05 pm »
    Thanks man, yea will do.. 398 is crazy
    Offline dan vbv
    • 300hp might not be enough
      • seaton delaval
    « Reply #4 on: October 03, 2014, 04:55:58 pm »
    It's not hard
    In the next few hours I will find out how much more than 395hp I have with a meth kit
    Big inter cooler
    My turbo is a gt2860rs
    on the standard exhaust manifold with a adapter plate which has been ported and matched to the head
    The head has had a lot of work  different cams  and porting
    Pistons and rods Lower comp
    Standard ecu with a remap
    Big injectors  700cc.
    Bit if you only want 300 hp you can do it on a smaller turbo  and have less lag
    I don't get full boost til 5000
    2002 ford ka rust edition
    2011 abarth 500 is now lightly modified
    1000hp single turbo supra 6speed manual   i want one
    Offline Skevy44
      • West Norfolk
    « Reply #5 on: October 03, 2014, 08:38:33 pm »
    What kind of modification is required to make the Astra VXR injectors work on the AGP?
    Offline dan vbv
      • seaton delaval
    « Reply #6 on: October 03, 2014, 08:54:59 pm »
    The setting of the ecu  the map needs rescaling as my mapper put it
    My car had insignia vxr injectors but thay where to small for 400 hp
    But thay just fit.
    And I needed colder spark plug 10s I think
    Offline SeanT-Jet
      • Hertfordshire
    « Reply #7 on: October 03, 2014, 09:18:56 pm »
    So are we saying the 2876 is gona be too big? And if so anyone got a 2860 or 71 up for sale? And Danaee you sayin the insignia injectors fit straight with only map modification?
    Offline dan vbv
      • seaton delaval
    « Reply #8 on: October 03, 2014, 09:29:38 pm »
    Injectors yes only mapping  to make them work
    If you want only 300hp then I think the 28 is to big
    I think a 25 might be better for your needs
    As on a 2860 my car only makes full boost at 5000rpm
    Hope this helps
    Offline SeanT-Jet
      • Hertfordshire
    « Reply #9 on: October 04, 2014, 12:41:53 pm »
    Any links for a good priced up 25 guys?
    Offline dan vbv
      • seaton delaval
    « Reply #10 on: October 07, 2014, 12:27:59 pm »
    Turbo technics  tell them what you want  and thay might be able to build you a turbo that is as small as possible that makes the power you want for quick spool
    I have found out that my car is making the max power it can
    With the meth fitted 400hp is it. Thay tried upping the boost and advancing the timing  but it just want make more power
    Intake temps never go above 25
    So i don't think more power is avalible with out  porting the head a lot more and fitting cams that would destroy off boost power  making it a out and out race car fitting a tube Exhaust manifold  removing the air con and fitting a bigger throttle body and plenum
    witch is know good as the car is my daily driver  work and back car
    But nitrous might just be a good idear
    Fast cheep reliable   Pick two. And the third is impossible
