Author Topic: Abarth Grande Punto 2009 wheel spacers  (Read 2410 times)
Offline mikescholes
« on: May 06, 2012, 12:42:03 pm »
I'm thinking my Abarth Punto would look a bit better if there wasn't quite the overhang from the wheel arch, especially on the back. Can anyone recommend a wheel spacer, back and front, thickness and what looks best?
Thanks all
    Re: Abarth Grande Punto 2009 wheel spacers
    « Reply #1 on: May 06, 2012, 03:37:23 pm »
    I must admit I've thought about it every now and then, the rear arch extensions do overshadow the wheels.
    Saying that I don't think there have been many people doing it on the Punto, seems to be more of a 500 thing.
    The rear of the Grande does dip quite a bit under load so you won't want to space them too much, no more than 6 or 8mm.
    Might also be worth getting proper spaces machined with centre rings and using longer/stronger bolts
    Offline Hawk
    « Reply #2 on: May 07, 2012, 01:10:23 am »
    or you could get some different wheels with a slightly lower offset  :thumb:
    Offline mikescholes
    « Reply #3 on: May 07, 2012, 07:59:10 pm »
    Thanks for that, 6-8mm hardly seems worth the effort and new set of wheels  is gonna cost, Think I might look at putting some larger tyres on, see if that makes it look any better. Might push out from the rim a bit more. Not sure how big I can go, got 205s on there at the mo.
    Offline mikescholes
    « Reply #4 on: May 08, 2012, 12:29:38 pm »
    Just ordered some 16mm hub centric spacers fro JJC, see how they go.
    « Reply #5 on: May 08, 2012, 01:50:35 pm »
    16mm on each hub? :o
    Have a feeling that's going to tramline like crazy! :(
    Offline mikescholes
    « Reply #6 on: June 17, 2012, 07:21:10 pm »
    They sent the wrong ones and the replacements would take 6 weeks so cancelled :(
