Author Topic: BMC Air filter  (Read 4343 times)
magicmole
BMC Air filter
« on: November 07, 2008, 12:59:08 pm »
Does fitting one of these invalidate the car warranty?
I know replacing the exhaust back box doesn't and that the BMC is fitted as part of the EsseEsse kit but I like to know about this point.
If nobody knows, I'll try to get to the dealers tomorrow.
« Last Edit: November 07, 2008, 05:21:53 pm by AlexK »
    Re: BMC Air filter
    « Reply #1 on: November 07, 2008, 02:22:21 pm »
    There is no black and white answer to this one. If you changed the air filter, and your brakes started to play up, there probably wouldn't be a problem. But if you changed the air filter and the engine management light came on, whether it was the filters fault or not, you are leaving yourself wide open for a bill to correct whatever is wrong.
    « Last Edit: November 07, 2008, 05:22:19 pm by AlexK »
    Offline Gofra
    Re: BMC Air filter
    « Reply #2 on: November 07, 2008, 02:54:50 pm »
    Its risky. Changing the air filter does allow engine to suck more air which deffinitely changes its behaviour. ECU might have some problems with that...
    « Last Edit: November 07, 2008, 05:22:25 pm by AlexK »
    magicmole
    Re: BMC Air filter
    « Reply #3 on: November 07, 2008, 03:22:21 pm »
    Perhaps I might wait for the 5 years warranty to expire. ;D
    « Last Edit: November 07, 2008, 05:22:31 pm by AlexK »
    Re: BMC Air filter
    « Reply #4 on: November 07, 2008, 04:15:13 pm »
    It's a dealer-supplied part, which you could ask your dealer to fit.  I can't see why there would be a problem, personally.
    Probably one to escalate to Italy, I reckon, via the dealer.
    I'd like to know a definitive answer to this, too, since I'm considering doing the same.
    « Last Edit: November 07, 2008, 05:37:16 pm by AlexK »
    Offline 1RV1N
    Re: BMC Air filter
    « Reply #5 on: November 10, 2008, 09:38:19 pm »
    Hi guys,
    looks like BMC filter for GPA has some problems now.
    The problem is that due to the high temperature below the hood, the filter become deformed like this:
    by now, we DO NOT KNOW if this is really a problem. We contacted BMC staff to have a reply about this. They are investigating the issue, i will let you know as soon as I will have any news (in a few days, I think).
    DON'T PANIC FOR THIS: nobody had engine failures or broken parts due to this issue. BMC does not know if this really is a problem. The odd fact is the the K&N filter does not get deformed, and not every BMC get deformed (10% is good, 90% gets deformed). However, BMC is a good company and it's making tests to give as an answer as soon as possible. Many EsseEsse in Italy are equipped with BMC filter, and no one had problem.
    I'll keep you updated from Italy. I have a brand new BMC filter, and I'm waiting for equipping it.
    Bye,
    Irvin
    Offline punto_matt
    Re: BMC Air filter
    « Reply #6 on: November 11, 2008, 08:06:34 am »
    Get one of these on it. Will give you a few more BHP and a bit more torque ;) Nice custom made bit of kit that is routed better than the standard airbox.
    My dealer hasnt said anything to me about it when its been into them for warrenty work in the past.
    Old Boy
    Re: BMC Air filter
    « Reply #7 on: November 11, 2008, 11:21:07 am »
    I noticed that the engine bay does get exceedingly hot.
    Re: BMC Air filter
    « Reply #8 on: December 17, 2008, 12:02:28 am »
    UPDATE: John's posted about a revised filter here:
    https://www.abarthforum.co.uk/index.php/topic,218.0.html
