Author Topic: Bonalume closed blowoff valve  (Read 3712 times)
Offline Gofra
« on: February 13, 2009, 06:51:21 pm »
I was in Graz (Austria) yesterday and had my oil and oil filter replaced at the local Abarth dealer there. I talked to the guy that owns the workshop and he mentioned me Bonalumes closed (that that doesn't make sounds :D) blowoff valve, that is suposed to increase the torque by up to 20 Nm. Is anyone kind enough to explain me how that works?
Afaik, the blowoff valve is only used for exhaust of the excess compressed air and frankly, cannot see how that would increase the power of the car by that margin (20 Nm is quite a bit).
Heres the pic:
...and heres their online shop page where its written about it in german:
http://www.fiatshop.com/shop/catalog/-p-801011018.html?osCsid=f251e647d636f11fcdeb583c95da3e23
...and here what google translates says (doesnt really say much :D):
Quote
The valve is closed, and provides approximately 20Nm more performance. Der Ladedruck des Turboladers wird mit Hilfe des Ventils schneller auf- und abgebaut. The boost of the turbocharger using the valve on and quickly dismantled. Dadurch hängt das Fahrzeug besser am Gas. This depends on the vehicle better gas. Das Ventil sorgt für KEIN lautes ZISCHEN und PFEIFEN, sondern ist eine Optimierung des Motors. The valve ensures no loud hissing and whistling, but it is an optimization of the engine. Einbauanleitung wird mitgeliefert. Installation instructions included. Einbauzeit in der Fachwerkstätte ca. 1,5h. Installation time in the professional workshop about 1.5 h.
Is this thing worth to go for?
    chunkymonkey
    Re: Bonalume closed blowoff valve
    « Reply #1 on: February 13, 2009, 06:58:20 pm »
    Afaik, the blowoff valve is only used for exhaust of the excess compressed air and frankly, cannot see how that would increase the power of the car by that margin (20 Nm is quite a bit).Heres the pic:
    Quote
    doesnt it stop the excess air slowing the turbo vanes back down as the throttlle butterfly closes?
    Offline Gofra
    « Reply #2 on: February 13, 2009, 07:22:27 pm »
    The way I understand, the valve is conected to the plastic hose (the one fixed on the engine cover) in to transfer that excess air to the turbine in order to keep it spooling. This way, the turbine doesn't start spinning from zero and thus, the lag is decreased. Other theory (which sounds more believable) is that excess air must not be left out on the open (I know some countries enviromental laws forbid that - Austria for ex.) so they connected the valve to the passage that leads back to turbine.
    I wonder what that orange box does  :)
    chunkymonkey
    « Reply #3 on: February 13, 2009, 07:52:39 pm »
    but isnt that just what the standard bypass valve does anyway, lets the excess pressure back into the turbo inlet?
    Offline Gofra
    « Reply #4 on: February 13, 2009, 08:18:38 pm »
    Yeah, and the more I think of it, the less I understand how someone could actual "gain" from this Bonalume thingy ;)
    Old Boy
    « Reply #5 on: February 13, 2009, 08:26:37 pm »
    Perhaps it's a little fan which blows air back in?
    Or maybe a magnet that lines the fuel molecules up making them burn more efficiently?
    Or even it's a supercharger running on snake oil?
    magicmole
    « Reply #6 on: February 13, 2009, 08:35:17 pm »
    You're just being cynical.
    It's none of those. It actually extracts energy from ley lines.
    Off topic - I've just noticed your image. Why have you painted the front of your car girly pink?
    Old Boy
    « Reply #7 on: February 13, 2009, 08:49:49 pm »
    That's not pink.  That's the blood of the last person who tried to insinuate I drive a girly car  ;D
    Anyway, you have pink wheels  :wave:
    chunkymonkey
    « Reply #8 on: February 13, 2009, 08:51:22 pm »
    someones posted a link to this bonalume thingy before, on a thread about dump valves, will have a look now.
    chunkymonkey
    « Reply #9 on: February 13, 2009, 08:55:10 pm »
    funnily enough, the thread was titled 'dump valve'. ::)
    it seems the general consensus was not to bother.
    magicmole
    « Reply #10 on: February 13, 2009, 08:59:08 pm »
    Yes, pink's lighter than red. Saves weight.
    Offline punto_matt
    « Reply #11 on: February 14, 2009, 12:21:59 pm »
    The only way a recirc/dump valve will increase performance is by keeping the turbo spooled up therefor reducing lag. It wont increase torque.
    Offline richardmajor86
    « Reply #12 on: February 14, 2009, 07:15:21 pm »
     ;D
