Author Topic: Removing silencers  (Read 2838 times)
Offline Reece
Removing silencers
« on: September 21, 2009, 10:13:05 am »
Morning guys
Thinking about removing the middle and rear silencers on my AGP. I've been driving around in my brothers A500 and love the sound it makes and would like my Abarth to sound sort of like this.
Do we think that removing bother silencers and having a straight through pipe would be to loud.
Your thoughts, opinions and advice as always please.
Reece
    magicmole
    Re: Removing silencers
    « Reply #1 on: September 21, 2009, 07:02:21 pm »
    Remove both and you will have no silencing at all. Yes, it will be loud. Very loud.
    Offline richardmajor86
    « Reply #2 on: September 21, 2009, 07:52:22 pm »
    Loud enough to make your ears bleed a little.
    Offline cb500t
    « Reply #3 on: September 21, 2009, 08:22:23 pm »
     :thumbd:
    Old Boy
    « Reply #4 on: September 21, 2009, 08:51:49 pm »
    Taking one of the silencers out would be a better option IMHO
    Offline Reece
    « Reply #5 on: September 22, 2009, 08:35:41 am »
    Yea i have heard a VXR with both silencers removed and it was a bit deafning.
    So what would you guys suggest then? The middle or rear silencer?
    Reece
    « Reply #6 on: September 22, 2009, 11:01:52 am »
    No  technical knowledge on my part, remove centre silencer, exhaust gasses have longer to travel before hitting a restriction and possibly moves center of gravity back a little bit.
    This could be a load of bo**ocks.
    Martin
    « Reply #7 on: September 22, 2009, 08:04:29 pm »
    Martin
    sounds alright though!
    ad087
    « Reply #8 on: September 23, 2009, 12:12:39 pm »
    Martin
    I would agree - middle one makes more sense than the rear. Turbos live on having as low a pressure across the exhaust turbine as possible to aid spool up. Although there is still a couple of restrictions (cats and rear silencer) overall back pressure of the exhaust will be reduced.
    *dealer hat on*
    Only problem you face is that it will of course affect your Warranty.
    Weight wise - technically yes, but not a huge amount! ;)
    magicmole
    « Reply #9 on: September 23, 2009, 12:45:00 pm »
    *dealer hat on*
    Why would that be?
    When I had my Ragazzon cat-back system fitted by my dealer they said that the warranty wouldn't be affected. Removing the cat, however, MIGHT affect the warranty, they weren't sure about that at the time.
    « Last Edit: September 23, 2009, 02:27:08 pm by magicmole »
    Offline dynamoMT
    « Reply #10 on: September 23, 2009, 02:11:13 pm »
    And what is likely to go wrong (warranty wise) by removing centre silencer????
    Offline Missing in Action
    « Reply #11 on: September 23, 2009, 02:12:00 pm »
    will it pass its MOT with the silencer removed?.... or am i been a tad stupid here....
    The one with the cape!
    ad087
    « Reply #12 on: September 23, 2009, 02:38:23 pm »
    That would be a judgement call on the tester, i.e. if they thought it was too loud then they could flag it - but would need to be pretty excessive.
    Why would that be?
    The way I would see it in your warranty is that if by removing it, there was a knock on effect (excess wear on the turbo etc) then a dealer may just draw the line at the modified exhaust and say "There's your problem".
    Final Edit: Removed some opinion from this. Service book outlines what can and can't be done to the car for your warranty to be maintained. I won't be commenting on issues like this again as it will just end up opening a can of worms.
    « Last Edit: September 24, 2009, 09:20:54 am by ad087 »
