Author Topic: Brembo brake pad change help  (Read 1872 times)
Offline A.C.J
« on: February 21, 2012, 02:26:32 pm »
Hi
I tried to change my pads yesterday bon my apg ss but failed due to being unable to remove the pins in the callipers,
Has anyone done a pad change before and can offer some advice of instructions please
Thank you
    Offline 3k5k
    • Exactly how long is it.
      • Doncaster
    Re: Brembo brake pad change help
    « Reply #1 on: February 21, 2012, 03:01:06 pm »
    You need a small punch slightly less in dia than the pin.
    Punch the pin out from the near side of the caliper, you will be able to grab the pin with your fingers from the rear of the caliper and wiggle it free.
    50 Shades of Campovola
    « Reply #2 on: February 21, 2012, 05:18:23 pm »
    use a concave headed punch, this stops it slipping off and chipping your nice red paint. you can't mess about with it. give it a good whack and it will move :thumb:
    Offline barwell1992
    « Reply #3 on: February 24, 2012, 12:52:51 am »
    2 of mine were corroded in, to say the least i need to paint my calipers :@
