Author Topic: Front mounted intercooler  (Read 1450 times)
Offline Allyl90
    • Essex
« on: May 11, 2014, 09:25:03 pm »
Hi guys, looking at things for my 'wanted' list for the abarth, started looking at front mounted intercooler's and can only find one made by forge at around £400, is there a cheaper alternative to the forge? I see a lot of universal ones but not sure if they'd be ok?
Ally :)
    Offline emyrmac
      • Benllech
    Re: Front mounted intercooler
    « Reply #1 on: May 12, 2014, 09:42:50 am »
    Hey, If you find the the dimensions for the forge one which is either posted here or on FF and find a universal one the same size you can easily use that one. Get some silicone piping to match the piping diameter on the intercooler and on the cars standard inlet and outlet pipes going to and from the intercooler. I think youll need 45 degree silicone bends if i remember correctly and possible have to make a couple of mounting bracket yourself but will still be alot cheaper than buying a forge one.
