Author Topic: GPA Squeaking Brakes  (Read 4637 times)
Offline 1mmortal
  • "Moderately Cool" - as rated by AlexK
« on: January 11, 2009, 06:46:15 pm »
A few of us have been ona bout squeaky brakes...on the wrong topics! So i;ve created this post to continue the discussion.
Redirected from https://www.abarthforum.co.uk/index.php/topic,197.msg3815.html
Jet - You tried giving it a thrashing and see if the brakes still squeak?
I find that if you keep the heat in the pads they don't make noise. Difficult if you have passengers though  ;)
Ex-Abarthian BL08BLZ... GPA-SS (180) === Velocity Red Body/Charcoal Grey Wheels...
    Offline Missing in Action
    Re: GPA Squeaking Brakes
    « Reply #1 on: January 11, 2009, 06:48:27 pm »
    yea mine only squeel in traffic. - starting and stopping at lights. otherwise mine are fine :)
    The one with the cape!
    Offline 1mmortal
    « Reply #2 on: January 11, 2009, 06:49:34 pm »
    yep same - very low speeds i get a definite low-pitched whistle when pulling up.
    « Reply #3 on: January 11, 2009, 06:51:22 pm »
    or when i just set off, i have to go over speed bumps to get out my estate so i brake for those and it squeels... if i stop hard for them it stops the squeel :)
    like 1mmortal says get heat in them and there fine :)
    magicmole
    « Reply #4 on: January 11, 2009, 07:05:01 pm »
    It was suggested on the forum that copper grease applied to the pads would temporarily cure the problem. The tech at Autoworld said it wouldn't (twice) but after 4500 miles I was getting p1ssed off with the squealing in traffic and had some applied when my wheels were replaced. Well, after 2 weeks they're still squeak free.
    Offline 1mmortal
    « Reply #5 on: January 11, 2009, 07:07:29 pm »
    Cool - keep me updated on this, magic.
    « Reply #6 on: January 11, 2009, 07:08:31 pm »
    On all my cars and motorbikes copper slip has always cured the problem  ???
    surely though its only worked for a limited time?
    am i correct in saying its something to do with the shim with the abarth brake problem? or is that just the mjets/Tjets?
    if it is, is there any news on a revised shim for the UK cars?
    john
    « Reply #7 on: January 11, 2009, 07:10:18 pm »
    Well Chunky has put copper slip on every one that has come back and they all seem fine now.
    « Reply #8 on: January 11, 2009, 07:12:43 pm »
    well if it does work perminatly thats great news - id rather only take the 1 trip to the garage for the copper slip than a second one for a revised shim fitted so long as it was perminant  :thumb:
    Offline happycallis
    « Reply #9 on: January 11, 2009, 07:12:53 pm »
    On my bikes it would always be fine for the life of the brake pad (about 6k) and the car would be a little longer. My dad was a mechanic years ago and he has always put copper slip pn the back of the brake pads. The copper slip can start to wash away espically if you use a jet wash anywhere near the pads.
    As i think someone else has said on here that brake dust build up causes the noise, you could always try blasting the dust out and see if it happens or it takes some time to start happening again
    chunkymonkey
    « Reply #10 on: January 11, 2009, 07:16:37 pm »
    yeah, i deglazed the discs and flattened the pads too, copper slipped them and havent heard any more complaints.
    until we get an abarth in that needs a set of pads were not gonna know if they come with shims or not, solme have and some havent from the factory.
    « Reply #11 on: January 11, 2009, 07:18:04 pm »
    I didn't say it is perminant, it depends on usage and the dust build up.
    Ah Chunky, its about time you turned up in a technical thread :thumb:
    « Reply #12 on: January 11, 2009, 07:20:53 pm »
    haha yea cheers chunky - thx for clearing that up  :thumb:
    chunkymonkey
    « Reply #13 on: January 11, 2009, 07:21:21 pm »
    have i missed a load then?
    i have had man flu for the past 2 weeks, and both my boys are ill. so thats my excuse.   ;D
    « Reply #14 on: January 11, 2009, 07:22:52 pm »
    Has it effected your eyes and fingers then? That must be a really bad case ;D
