Author Topic: Intermittant power steering failure  (Read 1460 times)
Offline cb500t
« on: May 05, 2015, 06:26:30 pm »
Occasionally  my power steering just isn't there when I fire up the car,switching off the ignition and restarting brings it back,,,,,whats wrong and how's it fixed??????? TIA
    Re: Intermittant power steering failure
    « Reply #1 on: May 05, 2015, 08:10:17 pm »
    When you first start up, leave it a few seconds for the pump to pressurise the system. All should be ok.
    Offline cb500t
    « Reply #2 on: May 05, 2015, 09:13:12 pm »
    Its now done it on the move ..
    Offline Duncan
    « Reply #3 on: May 10, 2015, 10:46:18 am »
    Mine did it once, it's electric assistance and the car had done a lot of short runs with the lights, heater etc on and the battery was a bit low and I was told the voltage needs to be spot on or it can cut out.  Been fine ever since (hopefully)
    Offline jf11
      • York
    « Reply #4 on: May 10, 2015, 10:57:13 pm »
    How old are you (that car that is  ;D)  sounds like you need a new battery!
    John
    - with thanks to Svein Erling who created the cartoon of the Fiat 127
    picasaweb.google.com/.../yvu-408OlK9A0x59a-5u_w
    « Reply #5 on: May 11, 2015, 08:46:25 am »
    To rule it out, check that your steering fluid level is up to the mark.
