Author Topic: MOT Esseesse Help!!!!!!!!  (Read 6242 times)
Offline x18pjr
  • White gpa, esseesse, leather
« on: March 06, 2012, 09:17:17 am »
hi
 i have a esseesse and i'm due a MOT end of this month and i'm a bit worried
just asking has anyone had there esseesse MOT'd and passed
i have the TMC tune and exhaust system
Mod: Caps removed
« Last Edit: March 06, 2012, 09:23:14 am by GTMartin »
    Offline sandys
      • Bristol
    Re: MOT Esseesse Help!!!!!!!!
    « Reply #1 on: March 06, 2012, 09:29:05 am »
    Why would it fail?  ???
    « Reply #2 on: March 06, 2012, 09:34:31 am »
    Does it still have a CAT on it?
    Offline Andrew
    • Carlo Rating: 11
      • West Yorkshire
    « Reply #3 on: March 06, 2012, 09:34:51 am »
    I know of at least one AGP SS that has passed its MOT with flying colours. I'd remove the box for it though.
    Weekdays: Campovolo A500
    Weekends: White AGP SS
    Offline x18pjr
    « Reply #4 on: March 06, 2012, 09:51:26 am »
    yeh i still have the cat on,
    i have looked on dlva site and the abarth range of cars are not on there
    plus the 155 has a 159 co2, so the esseesse must have more but the limit for the G rate cars is 165 co2
    Offline ashley_r_84
    « Reply #5 on: March 06, 2012, 09:58:43 am »
    Turn sport mode off :thumb:
    Mine's going in later this month and I have the same mods so we shall soon see.
    CHICKEN & MEAT RACING.
    « Reply #6 on: March 06, 2012, 10:01:45 am »
    According to the Elaboration certificate the Esseesse has an identical CO2 level as the standard car.
    If you're worried take a copy of your certificate with you - that should confuse them enough to just pass it :thumb:
    MOD:Image resized
    « Last Edit: March 06, 2012, 10:39:44 am by GTMartin »
    Offline A84RTH
    « Reply #7 on: March 06, 2012, 10:35:45 am »
    If they cant find the exact car they have to do a pre cat test for emissions.
    It will pass the normal agp emission anyway with Tmc exhaust and tuning box. Mine did anyway. I got it check after fitting them both.
    It's all the suspension I'd be more concerned with. Although I have got a few tips on how to get it through all these if they do find play in anything and it is excessive. Mots are just visual checks so if for instance they can't see where the play is coming from they can't fail it. e.g covered up with something. :thumb:
    :)Kim & Anthony:)
    BMW 335i 309bhp at the wheels, 572nm of torque :-)
    Offline MarcoPolo
    « Reply #8 on: March 06, 2012, 01:35:17 pm »
    Get the car MOT'd at an Abarth dealer  ::)
    « Reply #9 on: March 06, 2012, 01:37:53 pm »
    you'll need the brake fluid changing as well, might as well let Abarth do it at same time :thumb:
    Offline A84RTH
    « Reply #10 on: March 06, 2012, 02:04:19 pm »
    Only if you trust your dealer.
    I didn't in the slightest. Everytime I took it in they couldn't find anything. I had to tell them what was up with it just for them to find it. (or point it out to them)
     Also all emissions machine if updated will have the same cars/ data on them and if I remember correct it just comes under Abarth t jet.
    :)Kim & Anthony:)
    Offline x18pjr
    « Reply #11 on: March 06, 2012, 05:10:30 pm »
    Change the brake fluid, why change it every service I have, plus I don't trust my Abarth dealer at the best of times, the brake to me would have to be changed if you was doing track days and hard driving
    Offline SJH
    « Reply #12 on: March 06, 2012, 05:19:34 pm »
    Seems to me to be the totally blindingly obvious answer.
    « Reply #13 on: March 06, 2012, 06:12:38 pm »
    oops, my brain is bad today, you don't need brake fluid, sorry :whistle:
    i'd still take it to Abarth for the MOT though :thumb:
    Offline x18pjr
    « Reply #14 on: March 06, 2012, 07:50:06 pm »
    If it fails then the dealer will know about it, I want  a outsider has I think I have a problem with my Suspension but the dealer say I don't, I have creaking sound on the back they said it was the rear seat so I took them out, still there over little dumps at slow speed
