Author Topic: Question about my koni kit  (Read 1733 times)
Offline nexus6
« on: December 23, 2015, 08:39:50 pm »
Hello all. I've managed to acquire a rare abarth koni kit to put on my grande SS. According to the abarth website the springs on these kits are eibach but other sources say there brembo. Which is it and if they're the same brembo SS springs I've already got is it worth getting an actual set of eibach pro to fit with the konis instead?
    Offline Andrew
    • Carlo Rating: 11
      • West Yorkshire
    Re: Question about my koni kit
    « Reply #1 on: December 24, 2015, 09:47:53 am »
    Well done on acquiring the kit  :thumb:
    Punto Koni kit = Brembo
    500 Koni kit = Eibach
    Not sure it's worth getting a set of Eibachs springs, as the SS springs do sit ever so slightly lower than the Eibachs.
    Weekdays: Campovolo A500
    Weekends: White AGP SS
    Offline nexus6
    « Reply #2 on: December 24, 2015, 11:19:10 pm »
    Thanks Andrew. It took some rummaging I can tell you. So no benefit to ride and handling by going eibach then ?wouldnt mind a few more mm higher if there was an improvement in the process.
