Author Topic: Hi, my first post  (Read 2867 times)
chunkymonkey
Hi, my first post
« on: October 30, 2008, 10:37:47 pm »
just thought id say hi, joined this evening.
im an abarth technician at vospers in plymouth, ive worked in the fiat brand for nearly ten years and am currently in the middle of doing my second esse esse kit.
just to put straight a point i read on another thread on here regarding not hitting the rev limiter, the way i interpreted the information given us when we went on the tech's course in italy was that when we connect the fiat diagnostic tool to the vehicle before fitting the kit, the maximum allowed time of overrevs was 60,000msec, which i understood to be a minute.
after this has been exceeded it was considered the engine would not be in a condition suitable for fitment of the esee esse kit.
other parameters are also considered before the kit is fitted, such as the ecu must never have been reflashed.
as you can see from the pics on the thread john501 posted, it is a very in depth job, with basically everything forward of and including the exhaust manifold replaced. the oil cooler and pipework is all changed, as is the thermostat housing. also the turbo inlet and outlet pipes are changed, along with the coolant inlet/outlet and oil inlet/outlet pipes,the MAP sensor, turbo boost sensor and housing pipe, and the injector rail and injectors.
ive listed the stuff that perhaps people may not consider would be replaced, as obviuosly there is the larger turbo etc.
its nigh on impossible to get to anything when the front nose cone of the punto is still fitted, so as you can see from pics this is all removed, which also involves an aircon degas/regas.
when the esse esse kit is finished, the oil is changed for selenia abarth 10/50, and the new oil change schedule becomes 6000miles, although the service schedule remains 18k.
hope some of this info may have been helpful.
« Last Edit: October 30, 2008, 11:34:58 pm by AlexK »
    Re: Hi, my first post
    « Reply #1 on: October 30, 2008, 11:34:44 pm »
    Welcome chunkymonkey, that's a pretty useful first post!
    ...the maximum allowed time of overrevs was 60,000msec, which i understood to be a minute...
    That makes a lot more sense.  I'd like to clear up the other thread, if you're 100% sure about this figure?
    ...other parameters are also considered before the kit is fitted, such as the ecu must never have been reflashed...
    One thing that really gets to me on other forums is 'kids' having mental re-maps with ballistic power figures who then expect their dealer to replace their turbo under warranty because they've blown it up.  Not that many kids will be buying Abarths, perhaps, but I assume this condition still allows updates to fix software issues, just not changes to the fuel map?
    « Last Edit: November 01, 2008, 10:48:10 am by AlexK »
    chunkymonkey
    « Reply #2 on: October 30, 2008, 11:46:12 pm »
    well i took the 60,000msec info from a powerpoint presentation that the Abarth guy showed us. he then e-mailed it to us.
    it was a little difficult to get down all the figures in the notes as they were being translated by a guy that spoke fluent but not perfect italian so there was a little confusion a couple of times, maybe thats where the 10micro second thing came from.
    yeah the ecu will still be ok to reflash if any further are required, but the esseesse kit cannot be fitted if the ecu has already been reflashed, eg if any one has tried to tamper with it or chip it themselves. the engine ecu upgrade is only downloadable from abarth and is tracked. its also a one use only file.
    another point i read on here was having the esseesse kit fitted then taking the white/graphite wheels off and replacing them with the originals. its just that when in italy they were very, very inisistent that the handling kit must always be fitted before the engine upgrade, its not permissable to have the engine upgrade without the handling kit. im not sure it would still be recognised as an esseesse if the handling kit had essentially been disrupted by having smaller wheels put on?
    is it possible this might have insurance implications too?
    Old Boy
    « Reply #3 on: October 31, 2008, 05:48:14 pm »
    Very useful stuff there.
    Can you answer any of the other questions I have posted on another thread?:
    Does the geo get changed as part of the handling work?
    If so to what settings (camber, caster, toe)?
    Anything added to stiffen the chassis (braces etc)?
    Don't understand how putting back the original wheels will affect handling much.  The rolling circumference is the same, just that the 18" wheels have lower profile tyres.  Would have thought the ride quality would be better on the 17" ones anyway.
    How can an engine that's hit the rev limiter a few times be "not in a condition suitable for fitment" of the kit?  Do Fiat think the engines are that fragile and don't have much faith in them holding together unless you potter about at 2k revs?
    Cheers
    chunkymonkey
    « Reply #4 on: October 31, 2008, 08:00:13 pm »
    the camber and caster are non-adjustable.
    the front tracking spec is front wheel toe in -1 +/-1mm, the guy in italy said its best to set it to parallel.
    there are no changes to the chassis as part of the esseesse kit.
    i agree with you on the wheels, i much prefer the standard alloys, however they were extremely insistent that the kit wasnt to be tampered with. i guess at the end of the day its your car and you can do with it what you want though!  :)
    i cant speak for the rules fiat have made. i would hazard a guess theyre just trying to ensure the utmost reliability, we were fairly suprised at some of the constraints put on fitting a kit, such as the parameters must be sent before the kit is approved/supplied, but at the end of the day its abarth that make the rules and we have to adhere to them.
    Old Boy
    « Reply #5 on: October 31, 2008, 08:25:59 pm »
    Thanks for the info.
    I have to say it's not really sounding like much of a handling kit.  Just seems to be stiffer springs and new wheels.  Brakes don't need upgrading IMHO and drilled disks are just a gimmic in my view.
    Oh well, must wait for my dealer to get their demo sorted with a kit so I can test it out.
    Offline Reteb
    « Reply #6 on: November 12, 2008, 07:29:50 pm »
    I too prefer the standard wheels to the esseesse supplied wheels.
    What happens to the standard wheels when you fit the kit?
    And do the standard wheels fit over the upgraded brake discs? I presume that they are the same size?
    Old Boy
    « Reply #7 on: November 12, 2008, 07:36:22 pm »
    You get to keep the original wheels, so you'll need to take another large car with you when you get it done so you can bring all the stuff back. 2 large boxes worth if you go for the full SS kit.
    Brake disk are just drilled versions of the original, no size difference so no effect on caliper spacing or not being able to fit inside the original 17" wheels.
