Author Topic: Is there any way to edit posts or give 'likes'?  (Read 1624 times)
Offline mj2k
« on: October 15, 2021, 10:19:26 am »
Apologies if this is the wrong forum, but I've been looking in vain for some way to give feedback for posts people have made (e.g. a 'like') and couldn't find any. If there isn't an easy way to do this, it'd be a nice little forum tweak to say 'thanks' to people who have given a helpful reply to a question.
And another one which I'm sure I'm just missing - is there any way to edit your own posts? I ended up giving 3 posts in quick succession in reply to someone's question when one edited post would have done the job.
Thanks in advance
    Re: Is there any way to edit posts or give 'likes'?
    « Reply #1 on: October 17, 2021, 03:06:09 pm »
    We introduced for a bit of fun the 'Carlo rating' If you like click on the (+) on the left hand side.
    You can modify your posts, but there is a time limit. Once this is exceeded, only a Moderator or Administrator can modify.
    Hope this helps.
    Offline mj2k
    « Reply #2 on: October 18, 2021, 09:59:53 am »
    Hope this helps.
    Thanks, I can't see the plus or the edit options on my posts.
    Must just be my account then, maybe because I'm still new?
    Offline mj2k
    « Reply #3 on: October 21, 2021, 03:06:23 am »
    I've now posted 22 times so have hopefully passed the 'minimum posts' test (if there is one) :)
    However I still can't click on a + to give a 'carlo rating' and the edit icon still does nothing, could there be a javascript issue perhaps?
    I'm using the latest version Chrome but it performs exactly the same on Edge...
    Is anyone else experiencing issues giving 'likes' or editing posts?
    « Reply #4 on: October 24, 2021, 03:12:01 pm »
    I have dug into the forums features an I think I have fixed it, you should be ok now to award Carlo points :thumb:
    Offline android_808
    « Reply #5 on: October 24, 2021, 05:12:15 pm »
    GTMartin, where should I be looking for this?
    On the left of post, using those in the thread as an example, I have
    Username
    Guessing user level, ie Administrator in your case, nothing for mj2k
    Position ie, Abarth Wannnabe/S2000 Member/etc
    Scorpion icons
    Profile pic (if set)
    Post count
    Carlo Rating
    Location (if set), so Herts in mj2k's case and blank for you and me.
    Icon row (view profile, personal message, email icon if set to allow messages)
    Offline mj2k
    « Reply #6 on: October 24, 2021, 05:59:01 pm »
    Username
    Scorpion icons
    Post count
    Carlo Rating
    Ahhh they're scorpion icons, I thought they were tiny mushrooms. Wondered what that was about  ;D
    Still no plus icon for me either and can't see it when I 'inspect element', guess I'll find out in a sec if I can edit posts now...
    Offline mj2k
    « Reply #7 on: October 24, 2021, 06:00:01 pm »
    ...nope.
    Offline mj2k
    « Reply #8 on: October 24, 2021, 06:05:38 pm »
    No plus icon for me, and I'm guessing the 'edit' icon should be in the 'moderator bar'?
    (screenshot attached, awaiting approval)
    Offline android_808
    « Reply #9 on: October 24, 2021, 06:56:44 pm »
    I didn't see an edit option earlier either.
    « Reply #10 on: October 31, 2021, 07:20:46 am »
    We have referred the likes to tech support to fix, so watch this space.
    Offline mj2k
    « Reply #11 on: October 31, 2021, 11:54:28 am »
    Thanks, any chance you could get them into look into why I can't edit posts too pls? Doesn't seem to be a problem for me on other forums using the same code and doesn't appear to be an issue for many others on this forum, so I'm assuming there's something funny with my profile record in the back-end database.
