Author Topic: iAndre - Abarth 595 Cabrio 1.4cc 145hp  (Read 6826 times)
Offline iAndre
  • Car Enthusiast
  • Pocket Rocket !!
    • Greece
« on: July 01, 2017, 11:33:42 pm »
Hey guys , so its been almost 10 days since i took my Abarth. Even as a stock it looks, sounds and feels great.
As i've noticed consumption is pretty good for a petrol engine. I've seen much higher consuptions in the VAG group, but in sport mode and over 130++ km/h the consuptions goes way higher than the average.
Also, it's really great at high speeds. Cornering stability feels great with the stock suspension and 16" wheels, but i cannot compare it with the others that using the Koni FSD (great suspension not for daily driving though).
A couple of days ago i made a high speed run on private land to see how it feels in high speeds and the result amazed me. I reached 201 km/h* (i had to brake for obvious reasons since i was running out of tarmac) and i was feeling the car really stiff, plus it could give much more than that. But, in such speeds suspension wasn't as good as i expected (plus the tarmac was a bit bumpy). I was expecting to be a bit stiffer. Acceleration was really great.
*I really doubt that top speed is only 210 km/h i believe that it's about 218 km/h. I will give it a shot as soon as i can and i will post the results. Also, i'm planning to put a Go Pro Camera in order to capture it and post it for demonstration purpsoses and of course in order to discuss it further.
Also, i've noticed that after 140++ km/h it becomes a bit noisy (it sounds like you have opened your window about 6-7cm). Not a big problem though, that noisy will be soon covered by the exhaust sound ..  ;D ;D ;D
Regarding the upcoming mods, I will post a list below and i will try to keep the topic updated with descriptions, pictures and videos. Stay tuned for more !!
PS: Any suggestions regarding the mods are appreciated.
PS2: English is not my native language, so forgive any mistakes that I have probably made.
Album Link: http://imgur.com/a/NoC5i
Youtube Channel: Carholic 66
Upcoming Mods List
Exterior
* Will be added within next week.
Interior
Engine & Exhaust System
Suspension
Brakes
Drivetrain
« Last Edit: July 02, 2017, 10:53:06 am by PORTHOS »
--------  myAbarth 2017  -------
https://www.abarthforum.co.uk/the-abarthisti-garage/abarth-595-cabrio-1-4cc-145hp-first-impressions-upcoming-mods/
    Offline iAndre
    • Car Enthusiast
    • Pocket Rocket !!
      • Greece
    Re: iAndre - Abarth 595 Cabrio 1.4cc 145hp
    « Reply #1 on: July 13, 2017, 08:36:55 pm »
    Upcoming Mods List (Finally Updated  ;D ;D)
    Exterior
    Front & Rear Splitter - Red Finish
    Abarth Side Decals (Red Color)
    Mirror Covers - Red Finish
    Smoked look LED style side indicators
    Door Handles - Matt Grey Finish
    Boot Handle - Matt Grey Finish
    Front Whisker - Matt Grey Finish
    Rear Badge Surround - Matt Grey Finish
    Interior
    Sabelt Seats (Fabric)
    Abarth Aluminum Pedal set
    Abarth Aluminum Door Sills
    Abarth Aluminum Gear Knob
    Carbon Headrest Inserts (Until i buy the Sabelt Seats)
    Abarth Dashboard Decal
    Carbon Climate Control Cover
    Carbon Audio System Frame
    Carbon Gear Box Frame
    Carbon Center Console
    Armrest (not sure, it doesn't look good  :-\)
    Multimedia System (Haven't found anything yet)
    Engine & Engine Bay Styling
    Custom Re-map
    Airtec FMIC
    Forge Induction Kit
    Forge Silicone Intake Hose
    Forge BOV
    Uprated Injectors (In case of engine rebuilt)
    Bosch Upgraded Boost & Manifold Pressure Sensor (In case of engine rebuilt, if not they will remain stock)
    Upgraded Spark Plugs
    Stage 2+ Clutch Upgrade (In case of engine rebuilt, if not it will became stage 1)
    Stage 2 Shortshifter
    Garrett GT1446 Turbo Upgrade(Still Thinking Of It, It's Too Early For Something Like That)
    Forged Engine Setup (Still Thinking Of It, It's Too Early For Something Like That)
    Custom Aluminum Engine Cover
    Abarth Aluminum Oil Cap
    Abarth Aluminum Fuel Cap
    Biposto Radiator Cap
    Stainless Steel Engine Skid
    Exhaust System
    Custom DP 70mm
    Custom 200 Cell Sport Cat
    Custom straight pipe exhaust system 63.5mm or Mangetti Marelli Bombardone 2.0 straight Catback
    Wheels & Tyres
    Abarth Esseesse Alloy Wheels 17x7J (Black Chrome or Titanium)
    (I'm also thinking of Fondmetal 9RR, OZ Ultraleggera & MSW 85)
    Pirelli P Zero Nero 205/40R17
    Lug Nut in Black Chrome
    Aluminum Tyre Valve Caps
    Suspension & Drivetrain
    Bilstein B14 PSS Coilover Kit
    B14 PSS Top Mount
    PU Suspension Bushes Set
    Front Suspension Arm Kit (not sure about it)
    Racing Sway Bar Tie Rods (not sure about it)
    Rear Axle Adjustable Torsion Bar
    Front Axle Adjustable Torsion Bar
    Front Strut Bar
    Brakes
    Brembo 4pot front calipers with Ferodo DS2500 Brake Pads[
    Brembo 2Pcs drilled front rotors 305x28
    Brembo drilled rear rotors (OEM size)
    Goodridge Braided Brake Lines
    Window Tint & Lights
    20% Window Tint (Lumar Films)
    OE bulbs replaced with LED (Excluding Steering Lights)
    Low/High Beam Halogen PHILIPS (white color) bulbs
    Accessories
    Abarth Key Cover
    Abarth Tools Bag
    Aluminum Number Plate holder Black
    ** Its time a mod is made, i will re-update the post and of course i will post some pictures too. (there will be videos too)
    ** Main target for now is to achieve 190-200hp with a full stage 2. After that, the goal is to reach 270hp which is not difficult but not safe (for the engine). That's why it might need a "Forged" Setup.
    ** I would like to hear your opinions about the mods.
    Here is a pic i took 10 minutes ago.  ;D ;D
    Offline iAndre
    • Car Enthusiast
    • Pocket Rocket !!
      • Greece
    « Reply #2 on: July 25, 2017, 10:28:08 pm »
    So, i have made some mods already which made the car to look much better. It's a couple of simple things that makes the difference. I have added pictures in the album.
    - Low & High beam bulbs replaced with Philips Diamond Vision.
    (OEM fog bulbs will be replaced too with Philips Diamond Vision)
    - Abarth fuel cap.
    - Abarth oil cap.
    - Biposto's radiator cap.  ;D
    - BMC air filter.
    - Abarth side decals.
    - Abarth pedals & footrest.
    - Abarth door sill trim.
    - Abarth tools bag.
    - Abarth licence plate. (wasn't stock, it will take a bit more to receive it)
    - Smoked look LED style side indicators.
    - Interior led bulb.
    - Exterior "white" bulbs.
    ** Most of these were bought from TMC. Great guys and great communication. I would totally recommend them.
    Offline PORTHOS
      • Devon
    « Reply #3 on: July 28, 2017, 09:35:23 am »
    Looking fantastic :)
    Offline karadoulis
    • mini Lambo
      • Greece
    « Reply #4 on: July 28, 2017, 05:38:51 pm »
    Truth be told!  :thumb:
    Mendokusai
    Offline iAndre
    • Car Enthusiast
    • Pocket Rocket !!
      • Greece
    « Reply #5 on: July 28, 2017, 09:20:23 pm »
    Thank you guys , i'm glad you like it !!!   ;D ;D ;D
    Also, today i received my GoPro, so there are a couple of videos that will be uploaded soon.  :D :D
    Offline iAndre
    • Car Enthusiast
    • Pocket Rocket !!
      • Greece
    « Reply #6 on: August 01, 2017, 02:08:12 pm »
    Finally, i've changed to side "Abarth" decals, they were placed incorrect from the dealer but one of my friends has a wrap company and they placed the new one. Also, a "GoPro" sticker were placed. Plus, i've made a decal for the front plate to avoid drilling the front bumper.
    What do you think guys ?
    « Last Edit: August 01, 2017, 08:55:14 pm by GTMartin »
    Offline iAndre
    • Car Enthusiast
    • Pocket Rocket !!
      • Greece
    « Reply #7 on: September 19, 2017, 04:58:17 pm »
    It's been a while since my last post. The last month a couple of more mods have been made.
    - Mangetti Marelli Bombardone SS500R2.
    - Red mirror covers.
    - Red front & rear splitter.
    - Forge air intake silocone hose.
    - Abarth aluminum gear knob.
    - LED number plate lights & resistors to avoid any warning lights.
    Offline iAndre
    • Car Enthusiast
    • Pocket Rocket !!
      • Greece
    « Reply #8 on: October 22, 2017, 04:33:06 pm »
    So, yesterday i received forge's new silicone breather hose and i installed it at once.
    Hope you like it. I personally loved it. Overall cost was 32€ (incl. shipping).
    Offline craig1527
      • chester le street
    « Reply #9 on: April 23, 2018, 06:08:33 pm »
    where do you get the red front and rear splitter ?
